16 years agoThe problem of custom instruction
I want to define instruction of multiplication,but there is a problem that I cann't solve. the code is: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; ...
16 years agoWhat's the issue you are running into?
Here is an example you can look at: http://www.altera.com/literature/ug/ug_nios2_custom_instruction.pdf http://www.altera.com/literature/ug/ug_custom_instruction_files.zip
