16 years agoThe problem of component editor
hello! I meet a trouble when I learn how to edit a new component.I add a new component "pwm_motor" to the SOPC builder,but the output port pwm_out's signal type should be export.but it isn't in th...
16 years agoHello,
I don't understant really what you expect. Join, I put an example of a component with a clock input interface, an avalon MM slave, and a conduit. There are the interface tab and the signals tab. If you want details about the interface and signals, cf the avalon interface specification which explain the role of each one (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf) (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf%29).
