21 years agothe problem of compactflash test
yesterday£¬my group produced the slot between compactflash card and up3 board
I first write a test code# include <stdio.h># include <stdlib.h># include <unistd.h> # include "system.h"# include "sys/alt_alarm.h"# include "sys/alt_irq.h"# include "altera_avalon_cf_regs.h"# include "altera_avalon_cf.h"# include "ide.h"# define ctl_base (int*)CF_CTL_BASE# define ctl_irq (int)CF_CTL_IRQ# define ide_base (int*)CF_IDE_BASE# define ide_irq (int)CF_IDE_IRQ int cardPresent(void); int main() { unsigned short usStatus, usBuffer[256]; unsigned int i; printf("cf card inert or not"); if( !cardPresent() ) { printf("error: Compact Flash card not detected.\n"); return -1; } IOWR_ALTERA_AVALON_CF_IDE_COMMAND(ide_base, IdentifyDeviceCmd); usleep(1); usStatus = IORD_ALTERA_AVALON_CF_IDE_STATUS(ide_base); usStatus = IORD_ALTERA_AVALON_CF_IDE_ALTERNATE_STATUS(ide_base); if(usStatus & StatusRegBitDRQ) { for(i = 0; i < 256; ++i) { usBuffer = iord_altera_avalon_cf_ide_data(ide_base);}
else
printf("error: drq not set in status reg\n");
return -1;
for(i=0;i<256;i++)
printf(¡°%04x\n",usbuffer); } } int cardPresent(void) { if( (IORD_ALTERA_AVALON_CF_CTL_STATUS(ctl_base) & ALTERA_AVALON_CF_CTL_STATUS_PRESENT_MSK) ) { printf("you have insert the cf card"); return 1; } else { return 0; } } the result is ¡±you have insert the cf card¡° ffffffff fffffff ¡£¡£¡£ ffffff why£¿ then i use the test code on our forum it only show nios2-terminal: Warning: Unable to verify whether your download cable is nios2-terminal: supported for Nios II systems. If you use an unsupported cable nios2-terminal: you may experience intermittent JTAG communication failures. nios2-terminal: Please refer to the file errata.txt included in the Nios II nios2-terminal: development kit documents directory for information on how to nios2-terminal: update your system. nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "ByteBlasterII [LPT1]", device 1, instance 0 nios2-terminal: starting in terminal mode (Control-C exits) the design of slot error£¿£¿£¿£¿£¿
