20 years ago
The problem concerning uClinux uploading to UP3
Hello everyone!I need your help now...
The problem is concerning uClinux uploading to UP3 board.
Here is my developing enviornment:
target board: UP3 Education Kit
Cyclone EP1C6Q240
TC58FVT160 Flash Memory 2MB(1M*16b)
1S42S16400B SDRAM 8MB
128KB(64K*16b) SRAM
Software: Quartus 4.2 + NIOS IDE1.0
Nios2linux1_3
Since there is no ptf file from linux_example support for UP3,i have no idea.
I try to use NiosII_lab_up3 ptf.
According to the Linux Quick Start Guide,creat Linux Kernel Project,Configure Kernel,then Build Project,waiting...
the final error are as follows:
2.6.x/drivers/char/altera_pio_button.c:112: error: `na_button_pio_irq' undeclared (first use in this function)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/altera_pio_button.c:112: error: (Each undeclared identifier is reported only once
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/altera_pio_button.c:112: error: for each function it appears in.)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/altera_pio_button.c: In function `button_release':
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drmake: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'
ivers/char/altera_pio_button.c:156: error: `na_button_pio_irq' undeclared (first use in this function)
make[3]: *** [drivers/char/altera_pio_button.o] Error 1
make[2]: *** [drivers/char] Error 2
make[1]: *** [drivers] Error 2
make: *** [_all] Error 2
And what's the matter,need to modify the UP3 ptf file? and how to?I'm a newer in this developing
what i should complete,is Web Server using in Industry data gathering,based on Nios-uClinux board system.(UP3)
Thank you for everyone here, it&#39;s my first title here,and english is not good. Maybe should description more details.http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
    Hi Justin,
    > The first problem is that i can&#39;t find the up3-flash datasheet(TC58FVT160),
    http://www.toshiba.com/taec/components/dat...60aft_axb_e.pdf (http://www.toshiba.com/taec/components/datasheet/tc58fvtb160aft_axb_e.pdf)
    You might want to search the u-boot sources at sourceforge to find a board that supports
    this flash device and just copy it into your board-specific tree.
    > So the second problem is where can I find some details using for this u-boot work,such as,
    > CFG_Nios_CONSOLE,CF G_GBL_DATA_OFFSET,CFG_Nios_TMRBASE,CFG_Nios_TMRIRQ and so on,
    > because the UP3 munual reference doesn&#39;t have this data.
    Yes, u-boot configuration isn&#39;t the easiest task. A nice document for Nios-II would be great ... maybe
    I&#39;ll take a stab at it once I have some spare time ;-) That being said, let me try to help with the
    following minimum configuration:
    1. top-level configuration
    All of the following are configured via SOPC builder and are in your ptf file with the tag shown
    in (braces):
    CONFIG_SYS_CLK_FREQ -the Nios-II clock frequency in hertz (clock_freq)
    CFG_RESET_ADDR -the Nios-II reset address (reset_offset + the device base)
    CFG_EXCEPTION_ADDR - The Nios-II Exception address (exc_offset)
    CFG_ICACHE_SIZE - Size of the icache in bytes or zero (nasys_icache_size)
    CFG_ICACHELINE_SIZE - Size of icache line in bytes (nasys_icache_line_size)
    CFG_DCACHE_SIZE - Size of the dcache in bytes or zero (nasys_dcache_size)
    CFG_DCACHELINE_SIZE - Size of the dcache line in bytes (nasys_dcache_line_size)
    2. memory base addresses
    Define all of these ... set size to zero if not applicable. These should be available in
    your SOPC builder memory map.
    CFG_FLASH_BASE - base address of flash
    CFG_FLASH_SIZE - size in bytes of flash
    CFG_SDRAM_BASE - base address of SDRAM
    CFG_SDRAM_SIZE - size in bytes of SDRAM
    CFG_SRAM_BASE - base address of SRAM
    CFG_SRAM_SIZE - size in bytes of SRAM
    3. memory organization
    CFG_MONITOR_LEN - the size in bytes reserved for u-boot
    CFG_GBL_DATA_SIZE - the size in bytes reserved for u-boot&#39;s global data (128 will do)
    CFG_MALLOC_LEN - the size in bytes of the u-boot heap
    These can be quite confusing, but they let you fine-tune your configuration. Normally, they&#39;re
    all defined relative to the u-boot text base. See the PK1C20.h file for example.
    CFG_MONITOR_BASE - u-boot text base address (same as the .cfg file)
    CFG_MALLOC_BASE - base address of heap
    CFG_GBL_DATA_OFFSET - base address of u-boot&#39;s global data
    CFG_INIT_SP - initial stack pointer
    4. required component configuration
    u-boot needs a uart and a timer. Here&#39;s the configuration macros you should use:
    CFG_NIOS_TMRBASE - base address of the timer used by u-boot
    CFG_NIOS_TMRIRQ - the interrupt request number used by the timer
    CFG_NIOS_TMRMS - the timer interval in milliseconds
    If the timer provides period registers AND the default count is not acceptable
    to you, you can configure CFG_NIOS_TMRCNT.
    CFG_NIOS_TMRCNT - value used to load the period registers of the u-boot timer.
    CFG_HZ - number of hertz per timer tick. This is used by networking code and is dependent
    on the timer macros above.
    CFG_NIOS_CONSOLE - Base address of the uart or jtag uart component.
    CONFIG_CONSOLE_JTAG - Define this when using the jtag uart
    CFG_NIOS_FIXEDBAUD - Define this when uart is fixed baudrate or with jtag uart
    CONFIG_BAUDRATE - the initial baudrate (or the fixed baudrate) in bps
    CFG_BAUDRATE_TABLE - a table of allowed baudrates. This has one entry for fixed rate uart/jtag
    E.g.:
    # define CFG_BAUDRATE_TABLE {115200} /* It&#39;s fixed */
    or# define CFG_BAUDRATE_TABLE {9600, 19200, 115200} /* Allows selection of rate via cli */
    I hope this is useful ... configuring u-boot via a gui would be great ... but, good or bad,
    if you want a very high level of control, editing a configuration file will force you to really
    know your code.
    If you have any questions or need additional information, just post or shoot me some email.
    --Scott
