21 years agoThe problem concerning uClinux uploading to UP3
Hello everyone!I need your help now... The problem is concerning uClinux uploading to UP3 board. Here is my developing enviornment: target board: UP3 Education Kit Cyclone EP...
21 years agoHi again:)
Thank you for your given links, i have down the software as follows: 1:uClinux-dist-20041215.tar 2:nios-gcc.tar 3:u-boot-1.1.2.tar And today i try to compile the uClinux kernel for NIOS,follow the point steps: $ make xconfig $ make dep $ make but when the final step 'make',following info appears: ----------------------------------------------------------------- /home/JustinYan/uClinux-dist/linux-2.4.x/include/linux/coda.h:116: redefinition of `struct timespec' {standard input}: Assembler messages: {standard input}:824: Error: Unknown pseudo-op: `.subsection' {standard input}:832: Error: Unknown pseudo-op: `.previous' {standard input}:1000: Error: Unknown pseudo-op: `.subsection' {standard input}:1008: Error: Unknown pseudo-op: `.previous' make: *** [init/main.o] Error 1 ----------------------------------------------------------------- I have no idea about it.why? The another problem i meet,is about the rpm command. I have download 'cdk-nios-example-u-boot-20040316cvs-20040317.src.rpm' for the U-boot. when: --------------------------------------------------------------------- JustinYan@JUSTINYAN ~/setup/cdk-nios-example-u-boot $ rpm -ivh cdk-nios-example-u-boot-20040316cvs-20040317.src.rpm cdk-nios-example-u-boot # ################################################# JustinYan@JUSTINYAN ~/setup/cdk-nios-example-u-boot $ rpm -qi cdk-nios-example-u-boot-20040316cvs-20040317.src.rpm package cdk-nios-example-u-boot-20040316cvs-20040317.src.rpm is not installed ---------------------------------------------------------------------------------------------------- why this package is not installed, the rpm command using is correct,i think. I'm a beginner , so forgive me for asking this simple questions. Thank you again!:) Best Regards! Justin
