21 years agoThe problem concerning uClinux uploading to UP3
Hello everyone!I need your help now... The problem is concerning uClinux uploading to UP3 board. Here is my developing enviornment: target board: UP3 Education Kit Cyclone EP...
21 years agoHi:
Thank you very much! This UP3 board is supply by Altera,using for the university NIOS competition.So we have no chose,also should build a web server on this board,based on uClinux operating system. According your suggestion,turn 'Nios PIO buttons support' off,build again,the former error disppear,but another error appears: -------------------------------------------------------- make: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2li nux.kernel_0.1.5/linux-2.6.x' ive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.ker nel_0.1.5/linux-2.6.x/drivers/net/smc91111.c:2062: warning: `MOD_DEC_USE_COUNT' is deprecated (declared at /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2lin ux.kernel_0.1.5/linux-2.6.x/include/linux/module.h:567) /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2lin ux.kernel_0.1.5/linux-2.6.x/drivers/net/smc91111.c: In function `init_module': /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2lin ux.kernel_0.1.5/linux-2.6.x/drivers/net/smc91111.c:2173: warning: assignment from incompatible pointer type make[3]: *** [drivers/net/smc91111.o] Error 1 make[2]: *** [drivers/net] Error 2 make[1]: *** [drivers] Error 2 make: *** [_all] Error 2 --------------------------------------------------------- Then i think it's the smc9111's problem, so i turn it off other errors appear: arch/nios2nommu/lib/.checksum.o.d: done. CC arch/nios2nommu/lib/string.o arch/nios2nommu/lib/.string.o.d: done. AR arch/nios2nommu/lib/lib.a GEN .version CHK include/linux/compile.h UPD include/linux/compile.h CC init/version.o init/.version.o.d: done. LD init/built-in.o LD .tmp_vmlinux1 nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .text) nios2-elf-ld: region ram is full (.tmp_vmlinux1 section .bss) nios2-elf-ld: section .data [00020000 -> 0002dfff] overlaps section .text [00020000 -> 0017b43b] nios2-elf-ld: section .init [0002e000 -> 0003a51f] overlaps section .text [00020000 -> 0017b43b] nios2-elf-ld: section .bss [0003a520 -> 0004afc7] overlaps section .text [00020000 -> 0017b43b] nios2-elf-ld: section .sbss [00020000 -> 0002003c] overlaps section .text [00020000 -> 0017b43b] make[1]: *** [.tmp_vmlinux1] Error 1 make: *** [_all] Error 2 make: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2li nux.kernel_0.1.5/linux-2.6.x' ------------------------------------- I don't know how to deal with this problem. Another questions: As some other embedded developing board as ARM-9,it has some crossing complie tools(arm-gcc), using in developing application through linux. So what about NIOS-board, does NIOS has the likely gcc developing eviornment(NIOS-gcc) When i develop the U-boot, do i need to using the nios-gcc, and how,using in linux system....? Thank you again!:) Best Regards!
