20 years agothe problem about multi-core CPU
1 Have you used the multi-core CPU in the PFGA ? when i used the multi-
core CPU ,i had some problem about it . i had used the mailbox for the my multi-core CPU design. i found the mailbox is equality to the two mutexs, and then , when i one CPU read the address and the other CPU write the same address at the same time . Whether or not can the mailbox protect the address and harmonize the two CPU to run right . if the mailbox can not protect the address , and then how to protect the address by the software ? 2 when use the multi-core CPU, how to programme the bootloader for the multi-core CPU? In the sopc builder , the each CPU have the respective software system for itself. the each CPU reset from the 0X00 address, however, the shared flash has one OX00 address . and then, how to i will plan flash for the multi-core CPU ?14 Replies
hi, Paolo. thank you for your help!
i do it according to you said, but, i can not always open in the quartusii's tools/sopc builder. i do not know why. i want to look the ERIKA Enterprise's niosii structure, i do not know the ERIKA Enterprise how to use the mutex in its design. do you send your project to me by the winrar or winzip tool? my email is wwsstt2001_163.com. thank you very much! - Altera_Forum
Hi Lucky,
I just sent you the uncompressed design resulted from the .QAR file on your private e-mail. In any case, the details on how to create the hardware can be found on the ERIKA Enterprise Reference Manual available on the web at the erika enterprise literature page (http://www.evidence.eu.com/nios2/literature.asp). bye Paolo - Altera_Forum
hi, Paolo
i have downloaded the files you send to me. thank you very much. but, the question always exist. i will experiment the sopc bulider according to the files to construct the nisoii with mutux. if i have some question, i wish i can discuss with you together. thank you! lucky bye - Altera_Forum
--- Quote Start --- originally posted by lucky@Nov 15 2005, 06:34 AM i have downloaded the files you send to me. thank you very much.but, the question always exist. i will experiment the sopc bulider according to the files to construct the nisoii with mutux.
thank you!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10975)
--- quote end ---
--- Quote End --- That's fine!... just post again the problem you have... Paolo
