20 years ago
the problem about multi-core CPU
1 Have you used the multi-core CPU in the PFGA ? when i used the multi-
core CPU ,i had some problem about it . i had used the mailbox for the my
multi-core CPU design. i found the mailbox is equality to the two mutexs,
and then , when i one CPU read the address and the other CPU write the
same address at the same time . Whether or not can the mailbox protect
the address and harmonize the two CPU to run right . if the mailbox can
not protect the address , and then how to protect the address by the
software ?
2 when use the multi-core CPU, how to programme the bootloader for the
multi-core CPU? In the sopc builder , the each CPU have the respective
software system for itself. the each CPU reset from the 0X00 address,
however, the shared flash has one OX00 address . and then, how to i will
plan flash for the multi-core CPU ?
    hi, Paolo. thank you for your help!
    i do it according to you said, but, i can not always open in the quartusii's tools/sopc builder. i do not know why. i want to look the ERIKA Enterprise's niosii structure, i do not know the ERIKA Enterprise how to use the mutex in its design. do you send your project to me by the winrar or winzip tool? my email is wwsstt2001_163.com. thank you very much!
    Hi Lucky,
    I just sent you the uncompressed design resulted from the .QAR file on your private e-mail.
    In any case, the details on how to create the hardware can be found on the ERIKA Enterprise Reference Manual available on the web at the erika enterprise literature page (http://www.evidence.eu.com/nios2/literature.asp).
    bye
    Paolo
    hi, Paolo
    i have downloaded the files you send to me. thank you very much.
    but, the question always exist. i will experiment the sopc bulider according to the files to construct the nisoii with mutux.
    if i have some question, i wish i can discuss with you together.
    thank you!
    lucky
    bye
    --- Quote Start ---
    thank you!
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=10975)
    --- quote end ---
    --- Quote End ---
    That&#39;s fine!... just post again the problem you have...
    Paolo
