20 years agothe problem about multi-core CPU
1 Have you used the multi-core CPU in the PFGA ? when i used the multi-
core CPU ,i had some problem about it . i had used the mailbox for the my multi-core CPU design. i found the mailbox is equality to the two mutexs, and then , when i one CPU read the address and the other CPU write the same address at the same time . Whether or not can the mailbox protect the address and harmonize the two CPU to run right . if the mailbox can not protect the address , and then how to protect the address by the software ? 2 when use the multi-core CPU, how to programme the bootloader for the multi-core CPU? In the sopc builder , the each CPU have the respective software system for itself. the each CPU reset from the 0X00 address, however, the shared flash has one OX00 address . and then, how to i will plan flash for the multi-core CPU ?
