20 years agothe problem about multi-core CPU
1 Have you used the multi-core CPU in the PFGA ? when i used the multi- core CPU ,i had some problem about it . i had used the mailbox for the my multi-core CPU design. i found the mail...
20 years ago --- Quote Start --- originally posted by lucky@Nov 12 2005, 11:34 AM i used the demo project of evidence in the quartusii5.0 and 5.1. i can open the project, but, i can not open the the niosii processor in the sopc builder, do you know why? i want to look it.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10946)
--- quote end ---
--- Quote End --- What is the error that SOPCBuilder is giving you? I just downloaded the archive available on the Evidence web site to be sure. Then, - I decompressed the archive in c: - I opened Quartus II 5.0 (from the about dialog box it says build 168 06/22/2005 SJ Full Version) - then I chose "Project/Restore Archived Project...", and imported the QAR distributed inside the zip file. - I opened the project (in my case the location is the default given by Quartus II, C:\evidence_demo_2cpu_1_1\evidence_demo_2cpu_1_1\evidence_2cpu_restored) - and I double clicked on the SOPCBuilder icon, that opened without problems. Please be sure to use a pathname without spaces, because SOPCBuilder refuses to open a project that has spaces inside the names... The sequence I just described is the same described in the ERIKA Enterprise Reference Manual. The amnual in any case describes the exact sequence of steps, with screenshots, needed to reconstruct the design: for that reason, I hope there should be no problem to recreate the design for another evaluation board... Paolo
