21 years agothe MAX® CPLD EPM7064 configuration controller
Hi the altera company provides two types configure methods: epm7064 and epm 7128.I think that the configure programme is different.The two different methods are used in different ...
21 years agoniosIIuser,
You are correct about the CPLD's purpose on the eval board, but actually the 1c12 eval kits have an EPCS serial flash that can be used to store hardware and software.. the boards power-up with a factory design that boots uClinux (and the linux software/file system resides in parallel flash). SUN2004, I believe the only reason for one device being larger than the other was because our config controller design was a tight fit on the 7064, and when Stratix came along (larger configuration size, more address pins to drive), we opted to upgrade to the next larger device to avoid any no-fit issues. I may be incorrect on this but that is what I remember.
