16 years agoThe different toolchain from niosWiki : disambiguous
Hi I am new on this forum. I got a nios2 board last years and i want to set up Linux on it. With the help of nioswiki.com i saw that there exist a distribution for mmu and for nommu (even if ...
16 years agonommu uclinux uses a special object format called "binary flat", and doesn't support dynamic libraries. so the toolchains are different.
I would suggest starting with mmu, as nommu branch will be merged into mmu. You may follow the try out of mmu linux first. http://nioswiki.com/try_out_without_compilation Then you may download the new tarball pointed at, http://nioswiki.com/linux/downloading_linux_distribution (http://alteraforum.com/forum/showpost.php?p=94092&postcount=3) - Hippo
