16 years agoThe data transfer
I want to send the data of array in the code to the SRAM,which function should I use? the format is like this: thank you in advance!
16 years agoWell you need to give more details about what you are trying to do, how you check the results and what you expect.
Remember to bypass the data cache when you check the results of a DMA transfer.
