21 years agoTFTP server stack size
In case anyone else is trying to use TFTP - the default stack size for the server daemon is being calculated as 12 bytes! I looked into the CDL for this component and found that the default stack size is being calculated using symbols which are not defined (at least I couldn't find them in my installation). When I manually changed the size to 4096 in configtool, it fixed the crashes I'd been experiencing. FYI...
1 Reply
Yes, if you look at the .ecc, the ecos config tool doesn't seem to know the CYG default thread stack size variable. When I checked my compilation, the stack size was eventually filled in correctly even though ecos config screen was showing 12.
--- Quote Start --- originally posted by patnystrom@Jul 9 2005, 10:08 PM in case anyone else is trying to use tftp - the default stack size for the server daemon is being calculated as 12 bytes[/b]! I looked into the CDL for this component and found that the default stack size is being calculated using symbols which are not defined (at least I couldn't find them in my installation). When I manually changed the size to 4096 in configtool, it fixed the crashes I'd been experiencing. FYI... <div align='right'><{post_snapback}> (index.php?act=findpost&pid=8236) --- Quote End --- [/b] --- Quote End ---
