16 years agoTest Nios II Software Build Tool (SBT) and keep NIOS II IDE 9.0 SP2
Hi, I want to test Nios II Software Build Tool (SBT) for eclipse .... and keep my Nios II IDE 9.0SP2 (backup reason). Is it possible to install nios ii software build tool (sbt) for eclipse (9....
16 years ago --- Quote Start --- Or... you could use the tools in a Linux environment ... You get the added benefit of >10x compile and significantly faster SOPC Builder generate times as well! --- Quote End --- I assume the significantly faster compile time is for compiling the NIOS software? Not for compiling the HDL design? If the HDL compiles and/or fits significantly faster in Linux, I may have to give it a try. --- Quote Start --- There is NO Quartus II Web Edition in Linux. --- Quote End --- Starting with Quartus II 9.1, there is a beta web edition for Linux. I am not sure when it will be non beta. I would assume it would be fairly stable even as beta is it must be quite similar to the subscription edition for Linux. Although, I have not tried any version for Linux myself.
