16 years agoTest Nios II Software Build Tool (SBT) and keep NIOS II IDE 9.0 SP2
Hi, I want to test Nios II Software Build Tool (SBT) for eclipse .... and keep my Nios II IDE 9.0SP2 (backup reason). Is it possible to install nios ii software build tool (sbt) for eclipse (9....
16 years agoOr... you could use the tools in a Linux environment where switching between versions can happen with just a few environment variable settings. :-)
You get the added benefit of >10x compile and significantly faster SOPC Builder generate times as well! Cheers, -slacker
