19 years agoTerasic DE2 - GPIO-Headers won't work
Hello I'm using the DE2 board and just wanted to implement the GPIO-Headers to connect external components. Before I begin to build own logics in VHDL and/or implement access to the po...
16 years ago --- Quote Start --- donq posting below is how my settings on GPIO SOPC Builder, ie, input port only. The problem is when compiling the file and check Pin-Out everything related to GPIO_0 is bidirectional. How can I solve this problem. Thank you. --- Quote End --- By carefully reading all the way to paragraph 2 of my previous reply. --- Quote Start --- ...you must connect the output pins from the output GPIO to output pin symbols on the Quartus page... --- Quote End --- This is the main block diagram / symbolic design page, where you edit the BDF file. If you continue to have problems at this level, I might suggest that you do one of the tutorials...
