Template is empty in the Nios II application and BSP from Template
Hi @dsun01,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Mind if I asked what are the WSL version installed? Currently we are only supporting WSL 1.
Also what are the windows 10 build version that you are having?
Hope to hear from you soon.
Note: the details steps of installing a WSL on window can be found here.
Best Wishes
BB
- dsun014 years ago
Contributor
Hi BB,
I am very glad to hear from you, I understand you always have higher priority project to support, and my issue is low level tools setup.
here is my system configuration.
Win10 PRO is version 2004, os build 19041.1415.
C:\Windows\system32>wsl --list --verbose
NAME STATE VERSION
* Ubuntu-18.04 Running 1
Ubuntu Stopped 1I don't know how to remove Ubuntu. hope it in stopped mode won't affect the Eclipse execution.
I read from an old post that if I remove(uninstall NIOS II EDS, and delete all files and folders remaining, it will fix the problem), but I don't know how to uninstall the Nios II EDS.
how to uninstall Nios II eclipse - Intel Communities
thank you for your help.
David
