17 years agotelnetd all ports in use...?
Hello friends, Whenever I start 'inetd &', I try to access the board through telnet, and the answer I get is all ports are in use. The board has just been powered up. The OS has just boot...
17 years agoHello hippo,
I tried your suggestion. When I ran every command manually, none of them seemed to fail. However, when trying to telnet the board still couldn't. I figured a way to manipulate the board using files as 'flags' via ftp, which was already working. Thanks for you help Francisco
