21 years ago
tcp server socket problem
I've a problem with my tcp server socket. When I start my server socket and try to connect with a client application I the server socket do an error 88 (Socket operation on non-socket).
This problem happens only the first time that I try to make a client-server connection.
Can anyone help me?
thank you
StePa
this is my code:
int TCPIPserver(int fd)
struct sockaddr_in echoServAddr;
struct sockaddr_in echoClntAddr;
unsigned short echoServPort;
char firsttime=TRUE;
echoServPort =1024;
// Create socket for incoming connections
if((servSock = socket(PF_INET, SOCK_STREAM, 0)) < 0)
printf( "[TCPIPServer_Task] Socket() failed\n" );
exit(0);
// Construct Local address structure
memset(&echoServAddr, 0, sizeof(echoServAddr));
echoServAddr.sin_family = AF_INET;
echoServAddr.sin_addr.s_addr = htonl(INADDR_ANY);
echoServAddr.sin_port = htons(echoServPort);
// Bind to the local address
if(bind(servSock, (struct sockaddr *) &echoServAddr, sizeof(echoServAddr)) < 0)
printf( "[TCPIPServer_Task] Bind() failed\n" );
// Mark the socket so it will listen for incoming connections
if(listen(servSock, MAXPENDING) < 0)
printf( "[TCPIPServer_Task] Listen() failed\n" );
for(;;)
printf("[TCPIPServer_Task] Listening\n");
// Wait for a client to connect
if((clntSock = accept(servSock, (struct sockaddr *) &echoClntAddr, sizeof(echoClntAddr)) < 0))
else
// clntSock is connected to a client
printf( "[TCPIPServer_Task] Connected with client %s\n", inet_ntoa(echoClntAddr.sin_addr));
TCPClient_reset_connection(&conn);
conn.clntSocket=clntSock;
conn.fd=fd;
conn.remote_ip_address = echoClntAddr.sin_addr.s_addr;
conn.remote_port = echoClntAddr.sin_port;
conn.state = CLIENT_CONNECTED;
TCPClientRx();
if (conn.state == CLIENT_CONNECTED)
conn.state = CLIENT_CLOSE;
close(clntSock);
printf("[TCPIPServer_Task] Socket closed.\n");
