20 years agoTCP connection example
Hi, I am trying to make a TCP connection to a server with a nios II dev board. Does anyone have an example code on how that is done. I have tried with the following code with failing results, I think it has something to do with the destination IP.
The destination address is 192.168.1.2 which is set below. conn_sock = socket(AF_INET, SOCK_STREAM, 0); addr2.sin_family = AF_INET; addr2.sin_port = htons(5824); addr2.sin_addr.s_addr = inet_addr("192.168.1.2"); connect(conn_sock, (struct sockaddr *)&addr2, sizeof(struct sockaddr_in)); send(conn_sock, buf, strlen(buf), 0); close(conn_sock); Cheers. /ENo RepliesBe the first to reply
