16 years agoTCM speed advantage over onchip RAM?
(Please excuse if my ignorance of cache and bus technologies shows through my question) My NIOS FPGA application only uses on-chip RAM for code and data storage (no ext mem). Is there any spee...
16 years agoThat's a good point. If you plan on creating a design that has the code run completely on-chip then I would recommend these two configurations to ensure the maximum performance possible:
During Development:- Turn off the data cache
- Reduce the instruction cache to 512B
- Add a dual port on-chip RAM that will be pre-initialized with your code
- Hook up tightly coupled instruction and data masters to the dual port ram
- Reduce the instruction cache to 0B (this will remove the instruction master)
- Remove the JTAG debug module
- Regenerate the system
- Recompile the software
- Recompile the hardware
