21 years agoTCL Script File for Stratix II Board
Hi there, I'd received the new STRATIX II board with EP2S60F672C5ES device. To start my new Nios application I would like to use a TCL Script to auto assign the IO Pins. (like existing TCL ...
21 years agoin quartus->project there is a menu item: "generate tcl file for current project".
This I find useful because it generates a Tcl file which you can build on for adding pins, i.e. use as a template. In this way you dont have to fight too much with syntax issues in for instance namings of bus ports. In addition it will give a dump of all your current systems settings. Well is it realy all? I guess so at least. Sometimes you may find unexpected options (and incomprehensible ones too) listed there, which you didnt realize were set.
