16 years agoTarget request failed: No symbol table is loaded.
Sorry I don't mean to cross-post but I first asked this question in the following thread:
http://alteraforums.com/forum/showthread.php?t=22007 However that thread was originally created to deal with other more generic problems and my question is now more relevant to this forum. I'm receiving the following error when I try debug on my DE2 board: --- Quote Start --- Unable to set temporary breakpoint in main. Reason: Target request failed: No symbol table is loaded. Use the "file" command.. Continue? Yes | No --- Quote End --- GDB console output: --- Quote Start --- mi_cmd_stack_list_frames: No stack. No symbol table is loaded. Use the "file" command. 165-target-select remote :50681 165^connected,thread-id="0",frame={addr="0x00040020",func="??",args=[]} (gdb) 166-gdb-set new-console &"No symbol table is loaded. Use the \"file\" command.\n" 166^error,msg="No symbol table is loaded. Use the \"file\" command." --- Quote End --- The debug symbols obviously aren't being loaded for some reason however I'm unsure why. I am compiling and running debug mode so I'm unsure what the problem is. Any help would be appreciated.No RepliesBe the first to reply
