21 years agoTarget reboots during driver debug
I am debugging a modified lan91C111 driver for a custom board using the uCos telnet example (modified). Quartus4.1, NiosII CPU32 'tiny' IDE 1.0. The driver has been modified to use a 16bit...
21 years agotns1,
You've quite rightly deduced that if you have a rogue device driver debugging can be tricky. Your options are breakpoints or if you want hardware trace it's available from First Silicon Solutions http://www.fs2.com/ (http://www.fs2.com/)
