21 years agotarget processor: not responding
This is my first try with NIOS2 and the niosII_stratix_1s10_es eval. board. Compilation, cofiguration worked fine. I then invoke IDE and build Hello_world which gets downloaded to the board ok but...
21 years ago --- Quote Start --- originally posted by affluent007@Apr 4 2005, 07:58 PM using cable "usb-blaster [usb-0]", device 1, instance 0x00
pausing target processor: not responding.
resetting and trying again: failed
leaving target processor paused http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif
can you help? please help? i don't know where to start to look. --- Quote End --- The problem need to be discuss continuely. Because i have solved the wrong of open core, but i also can not drive nios II IDE's "run as nios hardware", the same word will occurs.
