21 years agotarget processor: not responding
This is my first try with NIOS2 and the niosII_stratix_1s10_es eval. board. Compilation, cofiguration worked fine. I then invoke IDE and build Hello_world which gets downloaded to the board ok but...
21 years agoaffluent007,
Do you have a valid license (either NIC-based or otherwise) for the Nios II processor? If not, then, as "flyingbowman" says, you _must_ leave this Window open in Quartus II. Closing the window, on an unlicensed core, will result in exactly the behavior you describe. If you are having licensing issues, that should definitely be something your local apps. guy can help with... :-) Cheers, - slacker
