21 years agotarget processor: not responding
This is my first try with NIOS2 and the niosII_stratix_1s10_es eval. board. Compilation, cofiguration worked fine. I then invoke IDE and build Hello_world which gets downloaded to the board ok but...
21 years ago --- Quote Start --- originally posted by affluent007@Apr 5 2005, 10:40 AM when i download the configuration which is "successfuly performed" i also get a window that says:
"click cancel to stop using opencore plus
time remaining: unlimited,
cancel"
i click on it and the window closes. does that have anything with it? http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/mad.gif --- Quote End --- I think it must keep the window opening instead of "cancel" it. In the compilation's reports,you can find a sentence say"Warning: Megafunction that supports OpenCore Plus feature will stop functioning in 1 hour after device is programmed". It's only my comprehends.
