21 years agotarget processor: not responding
This is my first try with NIOS2 and the niosII_stratix_1s10_es eval. board. Compilation, cofiguration worked fine. I then invoke IDE and build Hello_world which gets downloaded to the board ok but...
21 years agoI am following the tutorial to the letter. The clock frequency is 50Mhz. How can I tell
if the processor is brocken? The purpose of a tutorial is that it works right out of the box, I shouldn't have to add any debug hardware. There is a small difference between the tutorial and my actual SOPC it is this: Under the "Nios II More cpu Setting" I have the following: Reset Address ............ext_flash.............................0x00000000... 0x00000000 Exception Address...... ext_ram ..............................0x00000020....0x00800020 Break Location.............cpu/jtag_debug_module.....0x00000020....0x00900020 <<<<< not in tutorial In the tutorial I have only "More cpu Setting" and only the first 2 line. My local app. eng. is of no help. I leally need to get this system going asap. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Thanks guys.
