21 years agotarget processor: not responding
This is my first try with NIOS2 and the niosII_stratix_1s10_es eval. board. Compilation, cofiguration worked fine. I then invoke IDE and build Hello_world which gets downloaded to the board ok but...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused[/b] --- Quote End --- The reason nios2-download is trying to reset the processor and pull it into debug mode in one operation is that this doesn't allow any user code to be executed. So regardless of what you downloaded last time the processor should go into debug mode if its working. A failure message here normally indicates that the processor is broken in some way - please check that your clocks are running and within spec and that your reset is working correctly.
