22 years agoTarget Board specification?
I'm probably missing something obvious here, but... How do you create your own "target board"? SOPC builder's EPCS Flash device wants a reference designator from this, and the Nios II ...
22 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- Workaround: specify software directory created by IDE with undocumented switch --src=software.[/b] --- Quote End --- Mike, I think you may have pointed to the wrong directory with the --src= switch. You need to point it to the directory where the target board template files live. Try using the directory: C:/altera/kits/nios2/components/altera_user_board_setup
