16 years agosystem verilog simulation support in modelsim
hi all,
Does Altera Modelsim 6.5b supports system verilog simulation? I am simulating verilog files in which i have included system verilog .sv files using this modelsim version but it was giving error " Error: ecc_conf_model.sv(12): near "class": syntax error, unexpected "IDENTIFIER", expecting "class" ". To solve this i changed extension from .v to .sv so this error removed but when i go for nios to modelsim simulation same problem occurs because of sopc top level simulation .v file. so what is the solution for this...?5 Replies
I don't know!
But I think it must do it that becouse that Mentor!
Yes, Modelsim does simulate system Verilog fine.
But you need to tell it that the files are "system verilog". To do do go to the settings and change the default verilog file type to "System Verilog". - Altera_Forum
Up.
I know ModelSim works fine with SystemVerilog Files. I have lot of .sv with Type : SystemVerilog with Language Syntax : use SystemVerilog This error is everywhere on the web but i have not found any solution till now. - Altera_Forum
I believe you have to purchase a license from Mentor that supports SystemVerilog. That being said, I heard that supposedly Modelsim will support synthesizable SystemVerilog without the SystemVerilog license (not entirely sure on this).
Jake
