20 years agoSystem not generating with 2 clock sources
Hi folks, I am having a problem when trying to use two PLL’s on my Cyclone II EP2C35in SOPC builder. I have one 100MHz PLL derived from a 50 MHz oscillator and another 10Mhz PLL derived from th...
20 years agoHaving played about some more with SOPC builder I have noticed that if my counter module is running at a different frequency from the CPU then the system will not generate.
If I have my counter module and CPU running at 100Mhz, I can run the system ID peripheral, JTAG UART, RAM etc at 10MHz and the system generates correctly. If I try and run the counter at 10Mhz then the system will not generate. Has anyone experienced similar problems?
