16 years agoSystem Id mismatch
Everytime I make a change to my sopc system or quartus system and recompile, I am faced with system ID and timestamp mismatches. Even if I regenerate the BSP and ensure that the sopc info file used i...
16 years agoIt seems that after changing the sopc image you need to:
1) Run 'Generate' in sopc. 2) Compile the quartos 3) download the main fpga image - this takes 2 requests, since the first time it just notes that the file has changed! 4) rebuild the bsp 5) get the jtag debugger/downloader to reread the sopc version, it seems to cache the answer and needs a manual prod - IIRC if you get it to fail to download, there is a button to display the versions, then one to 'refresh' the valuie. You might be failing at step 5.
