16 years agoSystem Id mismatch
Everytime I make a change to my sopc system or quartus system and recompile, I am faced with system ID and timestamp mismatches. Even if I regenerate the BSP and ensure that the sopc info file used i...
16 years agoWhen you compile or change your sopc system, the .sopcinfo file gets altered and you are using the old sopcinfo file to run the Nios II that is why you were getting error. While creating the bsp application again works well because you use new .sopcinfo file.
