21 years agoSystem hangs in reset_device()
Hi, I'm using a Stratix II development board with NIOS II 1.1 and I am trying to initialize the network interface and the lightweight IP stack as done in the web server example. The network...
21 years agoYes, I've solved my problems booting both the processor from flash; i.e. setting reset address in flash (each processor at different address...) and using the flash programmer in IDE to download the codes. In this way u control the running of both the processor and then you could also download software directly to SDRAM...
