21 years agoSystem hangs in reset_device()
Hi, I'm using a Stratix II development board with NIOS II 1.1 and I am trying to initialize the network interface and the lightweight IP stack as done in the web server example. The network...
21 years agoHi Soin,
what I had was that both the program and data memory reside in partitioned sdram. I have tested this many other applications and it seems to work fine. But what you are saying is that when I download the quartus design onto the board, that the CPU's will already start to execute code? I thought they remained paused, untill you load the code into the memory with the JTAG... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
