21 years agoSystem hangs in reset_device()
Hi, I'm using a Stratix II development board with NIOS II 1.1 and I am trying to initialize the network interface and the lightweight IP stack as done in the web server example. The network...
21 years agoHi, I'm using a modified standard reference design. I'm quite sure the pins are connected properly, because sometimes it does work (after trying many times)
Also, when I take the standard web server example, it also works fine. My design in SOPC builder contains multiple CPU's. Could this be a problem? (the MAC is only connected to one cpu)
