21 years agoSystem hangs in reset_device()
Hi, I'm using a Stratix II development board with NIOS II 1.1 and I am trying to initialize the network interface and the lightweight IP stack as done in the web server example. The network...
21 years agoHi jmastron,
what hardware configuration design are u using?an example design or your own design? If it's your own, try first an example design; then, if it works, check the connections between FPGA and LAN91C111 pins, in your design.
