21 years agoSynthesis NIOS II source files by Leonardo
Hi, did you synthesis nios II source files by Leonardo Spectrum? I wasn't succesfull. Synthesis command "do_ip" caused this error "C:/work/projects/test/cls_kit_00/src/ni2....
21 years agoNios II is synthesizable using Quartus II only, sorry!
...there are a lot of reasons for this. Originally Nios I was synthesized with Leonardo. A couple of years ago Quartus native synthesis was greatly improved and we got the same (if not better results) using Quartus. This continues with Nios-II today, which has been hand-optimized in many ways to target Altera devices & use the Quartus II native synthesis. Please note that you can synthesize your own logic using Leonardo, for example if you create a custom peripheral or custom instruction and import it into your SOPC Builder system, the relevant wizards allow you to import a netlist.
