16 years ago
Syntax problem
Hi, there
I am working on the verification of video over IP reference design. The hardware part is ok. But when I import the software folder from original reference design, and build the projects, some errors occurs, here I listed some of them:
extern alt_avalon_rtp_tx_dev rtp_tx;
error: syntax error before "rtp_tx"
static alt_avalon_udp_ip_design_parameters udp_params;
error: syntax error before "udp_params"
fec_settings[i].EnableFEC = 0;
error: request for member `EnableFEC' in something not a structure or union
Can anyone help me to understand what happened, and how to correct these errors? Thanks. They make me very confused.
1 Reply
    The most probable cause of the error would be missing include/library file.
    Check if all the include/library files are in the path expected by your software application.
