21 years ago
Synchronous SRAM - Instruction and Data memory
Has anyone implemented synchronous sram for Nios instruciton and data store (ie execute out of synch sram)? I'm sure it can be done, but I'm wondering about the performance hit for opening access, and non-sequential execution of instructions. The cache could play in here as far as actual performance.
The avalon bus supports a feedback pin to indicate timing on the transfer. That is for transfers which are not always the same length. For example, the synch sram might take three cycles for an opening access, and then one cycle there-after (as long as the address are sequential).
I am thinking that you will loose cycles in the "glue" that stitches the synch sram to the avalon bus, and thus make the performance not as good as the Asynchronous SRAM that is used on the Altera demo boards.
Has anyone looked in detail at this?
Thanks for any info.
Eric Tauch
    this file "class.ptf" allows to use the onboard SSRAM as instruction and data memory on DSP Development Board:
    CLASS dspboard_ssram
    ASSOCIATED_FILES
    Add_Program = "";
    Edit_Program = "";
    Generator_Program = "--none--";
    USER_INTERFACE
    USER_LABELS
    name="SSRAM on 1s25 DSP Board";
    technology = "Memory";
    MODULE_DEFAULTS
    class = "dspboard_ssram";
    class_version = "2.0";
    HDL_INFO
    # An interface to this memory requires no additional files
    # in the target project directory.
    SLAVE s1
    PORT_WIRING
    PORT A
    direction = "input";
    is_shared = "1";
    type = "address";
    width = "18";
    PORT D
    direction = "inout";
    is_shared = "1";
    type = "data";
    width = "32";
    PORT adsc_n
    is_shared = "1";
    type = "always0";
    width = "1";
    PORT adsp_n
    is_shared = "1";
    type = "outputenable_n";
    width = "1";
    PORT adv_n
    is_shared = "1";
    type = "always1";
    width = "1";
    PORT bw_n
    is_shared = "1";
    type = "writebyteenable_n";
    width = "4";
    PORT bwe_n
    is_shared = "1";
    type = "write_n";
    width = "1";
    PORT clk
    is_shared = "1";
    type = "clk";
    width = "1";
    PORT chipselect_n
    type = "chipselect_n";
    width = "1";
    PORT mode
    is_shared = "1";
    type = "always0";
    width = "1";
    PORT oe_n
    is_shared = "1";
    width = "1";
    SYSTEM_BUILDER_INFO
    Active_CS_Through_Read_Latency = "1";
    Address_Alignment = "dynamic";
    Address_Width = "18";
    Base_Address = "--unknown--";
    Bus_Type = "avalon_tristate";
    Data_Width = "32";
    Has_IRQ = "0";
    IRQ_Number = "N/A";
    Is_Memory_Device = "1";
    Read_Latency = "1";
    Read_Wait_States = "0";
    Write_Wait_States = "0";
    Setup_Time = "1";
    Hold_Time = "0";
    SYSTEM_BUILDER_INFO
    Is_Enabled = "1";
    Instantiate_In_System_Module = "0";
    Hope that helps!
    Jochen
    http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
