21 years agoSynchronous SRAM - Instruction and Data memory
Hello, Has anyone implemented synchronous sram for Nios instruciton and data store (ie execute out of synch sram)? I'm sure it can be done, but I'm wondering about the performance hit ...
21 years agoEric,
They don't. It's the No Bus Latency or Zero Bus Turnaround feature that eliminates that problem when changing addresses or Read/Write direction. The Flowthrough basically makes it Asynchronous on the back side. So unless someone else knows more, ZBT/FT SSRAM is good stuff. Here is my summary: Fmax < 100 MHz: Use Asynch SRAM (10ns) Fmax < 133 MHz: Use ZBT,FT SSRAM (6.5ns) Fmax > 133 MHz: Use ZBT, pipelined SSRAM (3ns) SSRAM will additionally perform much better for sequential access if a smart controller that supports Burst mode is used. Then you can get data in or out every 6.5ns (FT) or <3.5ns (pipelined) Actually, If I read the datasheet correctly, I could read random values every 6.5ns if the controller would present the next address to the chip as it's reading the data from the last address. (one clock before) I don't know if the IUL or any other SOPC IP will do this, however. Here's a link I found usefull to explain the basics. http://www.cypress.com/cfuploads/support/a...ntroduction.pdf (http://www.cypress.com/cfuploads/support/app_notes/introduction.pdf) I think $15 for a 1 MB 32bit memory chip I can read in 6.5ns is pretty good! Ken
