21 years agoSynchronous SRAM - Instruction and Data memory
Hello, Has anyone implemented synchronous sram for Nios instruciton and data store (ie execute out of synch sram)? I'm sure it can be done, but I'm wondering about the performance hit ...
21 years agoThanks for your comments.
So why do you want to use the synch ram for an implementation that is non-sequential? I guess cost could be a factor. An asynch at 10ns could give you 66MHz no wait state bus (rough numbers). Whereas a 133 synch running non sequential would take 3 clocks per access for 44MHz overall through-put. Just wondering what your reasons for the synch ram are. I was considering the latency aware implementation for instruction execution. I am thinking the the UIL glue will still eat up a clock (considering a state machine control circuit). Perhaps some sort of simple logic circuit would preclude loss of clocks. I will have to draw up some bus cycles to see. Thanks, Eric
