20 years agoSynchronizing between ISR and main code
Hello all, What is the best way to ensure safe access to shared data between an ISR and the main code ? In my application, the ISR reads a packet from the FIFO of a custom UART and saves i...
20 years agoThe circular buffer is indeed useful, implementing a FIFO in software. I wanted, however, to avoid it and use something simpler, as I don't need a FIFO. I can, however, use a "trivial" FIFO which has depth 1 and "loses" all subsequent packets until the old ones has been read.
Which brings me to the question - are variable assignment and test atomic in Nios ? What I mean is:int ready;
// is this atomic ?
ready = 1;
// and is this atomic
if (ready == 1)
} I ask because I can make my main code "deassert" the 'ready' flag when it finished reading the packet, and the ISR to ignore a new packet if 'ready' is still asserted. This way no stomping occurs (overflow messages are lost, which is acceptable). So I wonder whether it's possible for the ISR to run in the middle of asserting 'ready' ? If "ready = 1" is atomic, it certainly can't.
