20 years agoSynchronizing between ISR and main code
Hello all, What is the best way to ensure safe access to shared data between an ISR and the main code ? In my application, the ISR reads a packet from the FIFO of a custom UART and saves i...
20 years agoHi eliben,
> What is the best way to ensure safe access to shared data between an > ISR and the main code ? That depends on what you are trying to do -- there's usually not a single "best way". > Is disabling interrupts during the main's code reading of the data the best option ? In most cases, no. This usually leads to those "mysterious" bugs that show up when baud rates, cpu clocks, etc. change. > What are the common guideline when dealing with data synchronization > in ISRs for Nios ? Here's a good reference: http://www.xml.com/ldd/chapter/book/ch09.html#t8 (http://www.xml.com/ldd/chapter/book/ch09.html#t8) A very simple and common technique is to use a circular buffer. The size of the buffer can be adjusted to meet your requirements ... provided you have adequate memory resources. Here's a basic overview: 1. The isr reads a "put" pointer, and writes its data. Then updates the put pointer. 2. The app compares the put pointer to a "get" pointer, when unequal, there is data. 3. The app reads (copies, consumes, whatever) the data, then updates the get pointer. Regards, --Scott
