19 years agoSwitch to external PHY on LAN91C111
Hi all, I have a design where I connect a fibreoptic interface via an external PHY to the LAN91C111. It worked well with the former releases of the NIOSII IDE using LWIP as TCP stack just ...
19 years ago --- Quote Start --- originally posted by slacker@Feb 1 2007, 07:16 AM i don't think much has changed with respect to the low-level driver of the 91c111. you can try doing exactly as you did in prior versions and, if it doesn't work (particularly with lwip), file it as a bug with altera. also, lwip support is not (yet) deprecated. it should function as before.
regards,
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21114)
--- quote end ---
--- Quote End --- Hi slacker, thanks for the reply. I fiddled arround with the file "\sopc_builder\components\altera_avalon_lan91c111\UCOSII\src\iniche\smsc91x.c" and "...\smsc_phy.c". I did it the same way as I changed the drivers in former times. (I added for instance some printf commands) But nothing really happened. So I decided to directly change the source in the components directory - after that I cleaned my project and recompiled it. But all of this has no effect. So did I take the right file? Or from where does the compiler get the sources? Best regards, Marco.
