19 years agoSwitch to external PHY on LAN91C111
Hi all, I have a design where I connect a fibreoptic interface via an external PHY to the LAN91C111. It worked well with the former releases of the NIOSII IDE using LWIP as TCP stack just ...
19 years agoI don't think much has changed with respect to the low-level driver of the 91c111. You can try doing exactly as you did in prior versions and, if it doesn't work (particularly with lwip), file it as a bug with Altera. Also, LWIP support is not (yet) deprecated. It should function as before.
Regards, - slacker
