15 years agosw+hw EPCS programming using Programmer / nios2-flash-programmer
Hi, I'm again facing a curious episode. I have a system that consists of a fpga with a nios processor (included a epcs controller) + epcs + external sram + external cfi flash. Currently I'm...
13 years agoDid you change reset vector in NIOS 2 CPU point to epcs flash.
In my project with DE2-115 board, I stored FPGA configuration in EPCS64, it has 8MB space and software in CFI_FLASH. In order to do that, I did these following steps: + CONFIG EPCS64 with .pof file (ACTIVE SERIAL PROGRAMMING mode instead of JTAG) + Make some changes with the SOPC builder: Your SOPC builder need to have CFI_FLASH or EPCS_CONTROLLER and change NIOS2 reset vector to EPCS or CFI flash + Regenerate BSP settings in ECLIPSE + USE NIOS2-flash programmer as user guide on altera wiki good luck with that
