15 years agosw+hw EPCS programming using Programmer / nios2-flash-programmer
Hi, I'm again facing a curious episode. I have a system that consists of a fpga with a nios processor (included a epcs controller) + epcs + external sram + external cfi flash. Currently I'm...
15 years agoI've just tried this method with no success :(
Something really strange is happening with my board.. or I'm taking some little mistake.. Using the GUI, it's similar to the command sequences that I tried to used before, with the advantage that it's no necessary to concern with the command syntax. Command lines that are used by the GUI:sof2flash
--input=".../quartus/hardware/hardware.sof"
--output=".../quartus/hardware/FNIOS/SOFTWARE/SBSP/flash/hardware.flash"
--epcs --verbose
elf2flash
--input=".../software/nios/software.elf"
--output=".../quartus/hardware/FNIOS/SOFTWARE/SBSP/flash/software.flash"
--epcs
--after=".../quartus/hardware/FNIOS/SOFTWARE/SBSP/flash/hardware.flash"
--verbose
--base=0x0 --epcs --sidp=0x2000100 --id=0x0 --accept-bad-sysid --device=1
--instance=0 '--cable=USB-Blaster on localhost ' --program --verbose --erase-all
--base=0x0 --epcs --sidp=0x2000100 --id=0x0 --accept-bad-sysid --device=1 --instance=0
'--cable=USB-Blaster on localhost ' --program --verbose --go I've attached the window with the jic creation configuration. It's really weird, that the fpga works when I program it using the jic file while the use of nios2-flash-programmer has no effect. Thank you again !
